<< Click to Display Table of Contents >> SpinReserveMode |
This property allows adjusting the load shedding algorithm's functionality regarding the usage of spinning reserves. Possible values for this property are 0 - MostPowerfulGenerator: Default, uses the spinning reserve of the most powerful generator on the electrical island or 1 - IslandGenerators: Uses the sum of spinning reserves of all generators on the electrical island.
NOTE |
This property's value cannot be changed while this object is active. |
