SetDisableTaskSwitching |
SetDisableTaskSwitching(Disable)
Enables or disables window switching. The Disable parameter is a Boolean value that indicates whether a window switching is enabled or not. This method updates Viewer's DisableTaskSwitching property.
NOTES |
•If more than one Elipse Power Viewer instance is executing on the same machine, and at least one of these instances use the SetDisableTaskSwitching method, that change affects all Elipse Power Viewers on this machine. •If users want to change window's title or style, the SetFrameOptions method must be used after calling the SetDisableTaskSwitching method. |
