IsAlarmArea |
Enables or disables the Alarm Area functionality for Server objects. This property is not available for Alarm Area, Alarm Server, Alarm Source, Collection of Historic Fields (Fields object), Collection of Storage Fields (Fields object), Historic Field, and Storage Field objects. Default value of this property is False (in case of Devices, its default value is True). When enabling this property, the object then contains the same properties of an Alarm Area.
