<< Click to Display Table of Contents >> StrokeColorDeEnergizedUserDefined |
Indicates whether the color for a de-energized Photovoltaic Power Plant must be the color defined in the StrokeColorDeEnergized property (True) or else it must be the color informed in the StrokeColor property (False). Default value of this property is False.
