Verify
Verify
Verify(OutputFile, [ObjectLink], [FixQuestionsDefault])
Executes an error verification in the current Domain and exports a list of errors found during this verification to a file in CSV (Comma-Separated Values) format. The parameters of this method are the following:
OutputFile: Path to save the file with the list of errors found
ObjectLink: Path to an object in the Domain to check. If this parameter is omitted, this check is performed in the whole Domain
FixQuestionsDefault: Indicates how to handle errors that can be fixed automatically by Elipse Power Studio. Possible values are 0 (zero, default), equivalent to answering No to all in the Domain Verifier option of Elipse Power Studio, and 1 (one), equivalent to answering Yes to all in the Domain Verifier of Elipse Power Studio. In this case, the errors fixed are not included in the output file
The generated file contains the Object, Error, Description, and Solution columns. This method returns the number of errors found during the verification.
