VertTextAlignment |
Determines a vertical alignment for an object's text. Possible values for this property are described on the next table.
Available options for the VertTextAlignment property
Option |
Description |
0 - TopAlignment |
Text's vertical alignment is on top of this object |
1 - MidAlignment |
Text's vertical alignment is centered in this object (default) |
2 - BottomAlignment |
Text's vertical alignment is at the bottom of this object |
