AddSubCondition
AddSubCondition
AddSubCondition([Name], [Caption], [Message], [Kind], [AckRequired], [Severity], [Value])
Adds a Subcondition object to the collection of Subconditions. This method has the optional parameters described on the next table.
Parameters of the AddSubCondition method
Parameter
Description
Name
Object's name. Corresponds to Subcondition's Name property. If omitted, the Subcondition is then created as "Subcondition". If the value passed on this parameter already exists in the collection, it is automatically incremented. Please check the general Name property for more information about the allowed characters on the names of objects
Caption
Object's description. Corresponds to Subcondition's Caption property. If omitted, Subcondition's description is an empty String
Message
Subcondition's message text. Corresponds to Subcondition's Message property. If omitted, Subcondition's message is an empty String
Kind
The type of behavior of this Subcondition. Possible values for this parameter are 0: Alarm, 1: Event, or 2: Return. Corresponds to Subcondition's Kind property. If omitted, Subcondition's behavior is 0 (zero, Alarm)
AckRequired
Indicates whether this Subcondition requires acknowledgment. Corresponds to Subcondition's AckRequired property. If omitted, Subcondition requires acknowledgment
Severity
The type of severity of this Subcondition. Possible values for this parameter are -2: Critical, 0: High, 1: Medium, or 2: Low. Corresponds to Subcondition's Severity property. If omitted, Subcondition's severity is 1 (one, Medium)
Value
Parameter containing a value that is evaluated to determine whether this alarm occurs or not. Corresponds to the Value property, common to all Alarm Sources. If omitted, Subcondition's value is Null
