DataField |
Configures or returns data linked to a Barcode object. This linked data can be a field from a database table provided by a Query object, a mathematical expression with Query fields and VBScript functions (in this case, this field must be preceded by an equal symbol), or an Elipse Power Tag or property. In this case, the current variable's value is displayed when printing. Default value of this property is an empty String.
NOTE |
The server must be executing so that a variable's value can be captured. |
