Properties
Properties
This section contains information about the properties of an E3Alarm object.
NOTE
Elipse Power uses, when defining coordinates and widths, the Himetric system. In this system, each logical unit is equivalent to one hundredth of a centimeter, that is, every 1000 units are equivalent to one centimeter. Thus, this is the standard adopted when describing Elipse Power properties, when applicable.
The available properties on this section are the following:
ActiveAlarms
ActiveCritAlarms
ActiveCritNACKAlarms
ActiveHighAlarms
ActiveHighNACKAlarms
ActiveLowAlarms
ActiveLowNACKAlarms
ActiveMedAlarms
ActiveMedNACKAlarms
ActiveNACKAlarms
AlarmCount
AlarmServer
AllowAckAll
AllowAckCurrentFilter
AllowAckSelected
AllowColumnClick
AllowDeleteUnboundAlarms
AllowShelveAlarms
AreaFilter
BannerMode
BorderColor
BorderThickness
ColorAckedAlarm
ColorActiveAlarm
ColorActiveEvent
ColorNAckAlarm
ColumnHeader
Connections
ConnectionStatusBarColor
CustomFilter
Domain
EnableSortMarker
Events
Fields
Filters
FilterType
Font
FourthSortAscending
FourthSortField
GridBkColor
InactiveCritNACKAlarms
InactiveHighNACKAlarms
InactiveLowNACKAlarms
InactiveMedNACKAlarms
InactiveNACKAlarms
PictureConnected
PictureNotConnected
PictureUnknown
PopupMenu
PrimarySortAscending
PrimarySortField
SecondarySortAscending
SecondarySortField
ShowConnectionStatusBar
ShowCriticalPriority
ShowHighPriority
ShowIcon
ShowLowPriority
ShowMediumPriority
SimpleAreaFilter
ThirdSortAscending
ThirdSortField
