<< Click to Display Table of Contents >> OnInactive |
OnInactive()
This event occurs while Elipse Power Viewer is inactive and if the EnableInactivity property is set to True. It is triggered when determining that a user is not using Elipse Power Viewer for a period of time equal or greater than the value of the InactivityTime property.
In a script for this event, users may program an action to perform when Elipse Power Viewer is inactive for a certain period of time. For example, users can perform an Elipse Power Viewer logout after 20 minutes without activity, as in the next example.
Sub Viewer_OnInactive()
Logout(false)
If MsgBox("This Elipse Power Viewer section was closed
due to inactivity.") = 0 Then
Application.GetFrame("").OpenScreen "InitialScreen", 0
