OnOperateFinished |
OnOperateFinished(ActorID, Failed, Canceled, FeedbackError, ScriptError, Aborted, Retries)
Event triggered when the Operate method finishes, successfully or not.
Description of parameters
Name |
Description |
ActorID |
Informs to a script the name of the user passed on the ActorID parameter of the Operate method in the Command Unit. If omitted when calling that method, assumes Elipse Power Viewer's user logon, "Anonymous" if there is no user logged on, or "System" if this method's call started at the server. |
Failed |
When set to True, indicates that a Command Action failed and this was informed by the Failed parameter of the script of the OnOperate event. |
Canceled |
When set to True, indicates that the Operate method ended prematurely. |
FeedbackError |
When set to True, indicates that a Command Action failed because the returned value could not be read in the specified time-out. This may occur because the returned Tag does not exist (a configuration error), or the value has a bad quality. For an incorrectly configured Tag (for example, a syntax error), it is possible that FeedbackError parameter be immediate (with no waiting time). |
ScriptError |
When set to True, indicates that a Command Action failed because the script had an execution error at some point. |
Aborted |
Indicates whether an Action failed because it was aborted, that is, if the Abort method was used. |
Retries |
Indicates the number of the retry in which this Action was finished. A value of 0 (zero) indicates that this Action was finished without retries. If the value of this parameter is different from 0 (zero), this event is only executed after the last retry. |
