Domain's Object Counting |
The Domain's Object Counting tool allows viewing the number of existing objects in a Domain, separated by classes sorted alphabetically or grouped by modules. This counting can also be performed contextually to an object, by right-clicking an object and selecting the Object Counting
item.
Domain's Object Counting window
Available options on Domain's Object Counting window
Option |
Description |
Sort by Category |
Displays object counting organized by module |
Sort Alphabetically |
Displays object counting organized alphabetically |
Refresh |
Refreshes the object counting. NOTE: This refresh process is not automatic, except when a removed object is the base object of the counting context or when a Domain is closed |
Count ElipseX's Instance Children |
Includes in the counting internal children of XControl, XFolder, or XObject instances |
Find |
Allows filtering this list by an object's name or partial name |
NOTES |
•The Object Counting contextual menu is not available in Organizer in Domain mode for Settings, Server objects, Files, and Remote Domains items. •Individual files on Files item in Organizer in Domain mode allow using the Object Counting contextual menu. •For password-protected files, they must be open to be added to this counting process. |
