Import and Export |
The import tool in Elipse Power reads information about objects from a CSV (Comma Separated Values) file, and recreates them in the configuration environment (Elipse Power Studio). For each object, users can get information on properties, Links, and collection items.
The export tool in Elipse Power stores information about selected objects from the configuration environment (Elipse Power Studio) into a CSV file. For each object, users can store its properties, Links, and collection items. Therefore, users can:
•Create new Elipse Power objects from a CSV file, as long as these objects are not direct child objects of the project or library
•Import or export any property from any type of Elipse Power object
•Import or export any type of Link from Elipse Power objects
•Export any type of Elipse Power's objects collection and import their properties
•Import or export any type of item from Elipse Power's objects collection
Any Elipse Power object can be imported or exported. The selected object for this operation is called the root object. So, users can import or export a Data Folder with user-defined XObjects, for example, or even export a Screen, listing all its child objects.
In addition to objects, Links and collections can also be imported and exported. Users have the option to inform whether they want to import or export Links and collections.
NOTE |
The import and export tool only considers properties and Links from Elipse Power objects and collections. Information not described in properties are not imported or exported. That is, for example, the case of scripts and internal settings of Screen objects. |
