Settings |
A PowerDisplay object contains all settings described on the next table.
PowerDisplay properties
Description |
Measurement |
Connection with a Measurement to monitor |
MeasurementSource |
Measurement Source used by this object: •0: Active Source •1: SCADA •2: Operator •3: Control Center •4: Billing •5: Calculated •6: Database •100: Topological Processor •101: Power Flow •102: State Estimator •103: Load Shedding •104: Distribution Load Modelling •105: Self-Healing •106: External Reader |
Format |
Configures a format to use, allowing both integers and decimal places |
BorderStyle |
Determines a border style to apply to this object: •0: Normal •1: Dash •2: Dot •3: Dash, dot •4: Dash, dot, dot •5: Null |
BorderColor |
Determines a border color to apply to this object |
