Line |
There are two options for a connection among Elipse Power's graphical devices:
•EquivLine: Connects to a Terminal of any device and extracts its status, energized or not, and the active power. With this information, it can animate that line and show the direction of power flow. This control contains a yellow dot that must be pointing to the Terminal to which it is connected
•Connector: Connects directly to the property that provides the status of a device's Terminal, animating this line's color. In addition, it connects to the graphical object and always moves with the device
