Data Server |
The Retentive property is not aimed to do this. It is only useful in Hot-Standby applications, to keep an Internal Tag value when there is a server switching.
By using Data Server's Save method.
Create a CurrentTime-type Demo Tag and link it to a Display on this Screen. A date and time format can be configured on the Formatting tab of a Display properties window.
By using a Square-type Demo Tag. This Tag must have its Enabled property set to False and its Period property set to twice the limit time, in milliseconds. By setting True to its Enabled property starts counting time. To execute any script at the end of this timer, create an event linked to this Demo Tag's Value property, which is executed when that property changes its value. In this script, users must also disable that Demo Tag, that is, set its Enabled property to False, so that it stops changing. It is recommended to use Demo Tag's Reset property before setting its Enabled property to True.
