E3Chart |
An E3Chart is an ActiveX component specially created to work with Elipse Power. With it, users can display charts with Tags varying in real-time, as well as historic data stored on a database.
An E3Chart is formed by several collections. A collection is a special object that manages a set of similar objects. An E3Chart contains the following collections:
•Collection of Axes: Manages the Axes of an E3Chart, where different scales linked to Pen's data can be configured
•Collection of Pens: Manages a set of Pens created to manipulate data sequences represented on an E3Chart
•Collection of Legend Columns: Manages the columns of an E3Chart's Legend, where information about Pens is then displayed
•Collection of Queries: Manages queries containing information about Pens, such as charts displaying historical data already stored on a database
To use E3Chart features, follow these procedures:
1.Right-click a Screen and select the Insert - E3Chart option.
Inserting an E3Chart on a Screen
2.If necessary, configure E3Chart properties. Some properties of this object can be configured using the Properties List, without creating scripts. To configure any property, locate it on Properties window and perform the necessary adjustments. For more information on E3Chart properties, please check the Elipse Power Reference and Scripts Manual.
