OPC UA Block Element
An OPC UA Block Element object enables reading or writing of one of the OPC UA Block Elements where it is inserted. An OPC UA Block reads a data table, and this object is always linked to the position defined by its Index property. To use this resource, follow this procedure:
1.Right-click an OPC UA Block and select the Insert - OPC UA Block Element option.
Inserting an OPC UA Block Element
Some properties of an OPC UA Block Element can be configured using the Properties List, without creating scripts for this. If users want to configure any property, locate it on the Properties List and perform the settings. For more information, please check Elipse Power Reference and Scripts Manual.
