Alarm Sources
Alarm Sources
All information relative to alarm conditions is defined in Alarm Sources, as well as event types that must be generated for each condition. Alarm Sources always contain an alarm expression or a data source, whose value can be checked according to several available conditions. The available sources are Analog Alarm, Dead band Alarm, Digital Alarm, Discrete Alarm, and Rate-of-Change Alarm.
NOTE
An Alarm Source object can be created inside any Server object.
To insert this object, follow this procedure:
1.Right-click the Server object in Explorer mode and select the Insert - Alarm option (Analog, Dead Band, Digital, Discrete, or Rate of Change). In Domain mode, select an object in Server objects item and then select the Insert - Alarm option (Analog, Dead Band, Digital, Discrete, or Rate of Change).
Inserting an Alarm Source
Some of these object's properties can be configured on the Properties List, without scripts. To configure any property, locate it on the Properties List and proceed with the necessary adjustments. More information on the functionality of this object's properties can be found on the Elipse Power Reference and Scripts Manual.
In each alarm sub-condition, users can configure its limits, an event-related message, its severity, as well as the need for acknowledging this event or not.
Alarm Sources
Alarm Sources
On the Properties window of any Alarm Source, select the Source tab to display the window on the next figure.
Source tab
Source tab
Available options on the Source tab
Option
Description
Data source
An expression that must be evaluated to determine whether this alarm can occur or not. This option corresponds to the Source property of all Alarm Source objects
Handle this alarm as an event
Indicates that this is an Event-type alarm, that is, when activated, it is acknowledged by the "System" user. This option corresponds to the Event property of all Alarm Source objects
Double Acknowledgment
Indicates that this alarm can be acknowledged when active and when inactive. This option corresponds to the DoubleAckRequired property of all Alarm Source objects
Exclude suppressed alarms from alarm counters
Ignores suppressed alarms of an Alarm Area on alarm's general counters. This option corresponds to the ExcludeSuppressedOnAreaCounters property of all Alarm Source objects
All Alarm Sources have the general properties described on the next table.
General properties of Alarm Sources
Property
Description
Message Text
This message is stored in alarm event's Message field while it is active, that is, it can be viewed on an E3Alarm or stored on a database. This message text is limited to 200 characters
Severity
Indicates the severity of an alarm, that is, Critical, Low, Medium, or High. The Severity field is used for building filters and for sorting messages
Need Ack
Indicates whether this alarm must be acknowledged by an operator to be removed from an E3Alarm's alarm list, or if it is automatically acknowledged when a variable leaves an alarm condition
Return Message
This message is stored in the alarm event's Message field when it is inactive, that is, it can be viewed on an E3Alarm or stored on a database
There are several types of Alarm Sources that can be inserted into Server objects. The available options are described on the next topics.
