SE1 Screen |
The Screen that contains Substation diagram must be modified to display on the Central_Area Splitter. The Alarm Summary must be moved to Alarm_Screen and that Screen must be renamed and resized.
1.Open InitialScreen and delete all objects.
2.Change this Screen's name from "InitialScreen" to "SE1_Screen".
3.Right-click this Screen and select the Fit to Splitter option.
4.On the window that opens, select the Central_Area Splitter and select the Set as initial Splitter's Screen option.
5.Repeat the diagram's import process, according to the previous exercise. Notice that the new size for this diagram is adapted to the available area on this Screen, now a little bit shorter.
6.Return to Frame1 object and check the configuration for these three Splitters.
Frame1
6.If any Splitter appears blank, right-click it and select the Initial Screen or Frame option.
7.On AppBrowser window, select the Screen corresponding to that Splitter.
8.Execute this application.
