PowerExplorer
PowerExplorer
Fixed a problem where Measurement columns are displayed closed when using a high DPI (Dots Per Inch). This bug occurred since v4.5.156.
Fixed a redrawing problem of text components of a Command on the Commands tab of PowerExplorer and Interlocks windows. In addition, the right border of Interlock's text was reduced. This bug occurred since v4.0.101.
Now on PowerExplorer window the Timestamp column of Discrete Measurements displays the timestamp of a Measurement's Value property, and not the value of the ValueCaption property.
Fixed the calculation of the size of an Interlock's message window to correctly fit its text. This bug occurred since v4.8.224.
Optimized the sort order of items on Measurement tabs of PowerExplorer window to avoid recreating the list after each change. This bug occurred since v4.7.79.
Fixed an error where the F5 key was not working to update PowerExplorer window. This bug occurred since v4.8.188.
Fixed a GPF when selecting tabs of PowerExplorer window with a disabled project. This bug occurred since v4.8.188.
