Importing and Syncing Elipse Power Objects
Fixed the calculation of Connector's width. This bug occurred since v3.5.200.
Fixed a problem on Elipse Power's Data Object Syncing tool, which allowed selecting a project outside the Domain to create a new object when there was an open Domain. This bug occurred since v3.5.81.
Fixed a problem when importing a Substation connected to another one by a Transmission Line, where the created Link's Source in the LinkNode's SourceObject property was not being filled. This bug occurred since v4.5.153.
Fixed a problem when importing Elipse Power's Screens from a Screen, which did not respect advanced configurations. This bug occurred since v4.6.89.
Fixed a problem when importing Elipse Power's Screen objects when the Screen's path linked to that object contained Folders. This bug occurred since v4.6.89.
Fixed a problem when importing Screens with LinkNodes when these ones were inside Bays in the electrical model. This bug occurred since v4.5.153.
Fixed a syncing problem with Branches of the electrical model without a defined cable that generated a needless log message. This bug occurred since v3.5.209.
Removed error messages on log when syncing (importing) Electrical Models with Line Segments defined at System level. This bug occurred since v3.5.81.
Fixed the size of Nodes when importing Elipse Power's Screen objects. This bug occurred since v3.5.228.
Fixed the order of items on the Import Screen Objects window to always list Substations first, then Feeders, and then Schematic Views, keeping the alphabetical order on internal items. This bug occurred since v4.6.89.
