Bit00 to Bit31 |
These properties together represent all 32 bits from the value in the Value property of an OPC UA Block Element object, where Bit00 is the least significant bit and Bit31 is the most significant bit. Changing each one of these bits implies in equally changing the Value property of an OPC UA Block Element and vice versa, but this only occurs when the UseBitFields property is set to True. Default value of these properties is False.
