Load |
Load(Configuration)
Loads a configuration saved by the Save method in the Configuration parameter. This method returns a value indicating the result of the load operation. Possible values are 0: Configuration was successfully loaded, 1: Configuration did not load successfully, 2: Configuration content is invalid, or 3: This configuration requires a newer version. The Show method fails and does not display the TrendAnalysis window in case of error loading a configuration.
