GradientStyle |
This property specifies a gradient fill style for a Screen. This property is only used when the FillStyle property is set to 8 (eight, Gradient). Gradients consider a color change as starting from the color configured in the ForegroundColor property and moving towards the color configured in the BackgroundColor property.
Available options for the GradientStyle property
Option |
Description |
0 - LeftToRight |
Vertical gradient, from left to right (default) |
1 - RightToLeft |
Vertical gradient, from right to left |
2 - VertToCenter |
Vertical gradient, from border to center |
3 - VertFromCenter |
Vertical gradient, from center to border |
4 - TopDown |
Horizontal gradient, from top to bottom |
5 - BottomUp |
Horizontal gradient, from bottom to top |
6 - HorzToCenter |
Horizontal gradient, from border to center |
7 - HorzFromCenter |
Horizontal gradient, from center to border |
8 - DiagDownRight |
Diagonal gradient to the bottom, with foreground color on the right |
9 - DiagUpLeft |
Diagonal gradient to the top, with foreground color on the left |
10 - DiagUpToCenter |
Diagonal gradient to the top, from border to center |
11 - DiagUpFromCenter |
Diagonal gradient to the top, from center to border |
12 - DiagDownLeft |
Diagonal gradient to the bottom, with foreground color on the left |
13 - DiagUpRight |
Diagonal gradient to the top, with foreground color on the right |
14 - DiagDownToCenter |
Diagonal gradient to the bottom, from border to center |
15 - DiagDownFromCenter |
Diagonal gradient to the bottom, from center to border |
16 - SpotBottomRight |
Gradient with foreground color, from right lower corner |
17 - SpotBottomLeft |
Gradient with foreground color, from left lower corner |
18 - SpotTopLeft |
Gradient with foreground color, from left upper corner |
19 - SpotTopRight |
Gradient with foreground color, from right upper corner |
20 - SpotFromCenter |
Gradient with background color, from center to border |
21 - SpotToCenter |
Gradient with background color, from border to center |
