SortMode
SortMode
Enum This property indicates the sorting mode for Measurements, Commands, and Protections on a PowerExplorer window. Possible values for this property are the following:
-1 - smNoSort: No sorting, that is, objects are displayed in the order they are returned by the server
0 - smAlphabetic: Alphabetical sorting (default)
1 - smTypeSorting: Object sorting is performed based on the values informed on the Sorting column, available on Analog, Discrete, Commands, and Protections tabs of a Power Configuration object
