CacheSize |
Defines the size of a record's block that must be read by a Historic before sending it to a database. For example, if this property is equal to 4 (four), blocks with four records each are sent to the associated Database object. Valid values for this property must be in the range between 1 (one) and 4 (four). Default value of this property is 1 (one).
NOTE |
A record block is sent every second, even if it does not reach the size configured in this property. |
