DeletePoint |
DeletePoint(lIndex)
Removes the Polygon Point indicated by the lIndex parameter, which is the index of the Polygon Point in the Collection of Polygon Points. Polygon Points can only be removed from a Collection of Polygon Points with more than two Polygon Points.
