DeletePoint |
DeletePoint(NameIndex)
Removes the Connector Point indicated by the NameIndex parameter, which can be an index as well as the name of this Connector Point in the Collection of Connector Points. Connector Points can only be removed from a Collection of Connector Points with more than two Connector Points.
