ShowBadPoints |
When this property is disabled, points with a bad quality are not plotted. If a Pen is drawing lines, the lines that cross bad quality points are not connected. For a point's quality to be considered in a Pen's historical part, the fieldname_quality field must be selected on E3Chart's Query. When this property is enabled, all points are plotted normally.
