SetTickSpacing |
SetTickSpacing(TickSpacing, TimeUnit)
Configures the space between scale divisions (ticks) determined by the TickSpacing parameter using the time unit indicated by the TimeUnit parameter. If the scale is numeric, this time unit is not considered. The available options for the TimeUnit parameter are described on the GetRealTimePeriod method.
