GetObject
GetObject
GetObject(ObjectPath)
This method returns a reference to the object specified by ObjectPath. This allows accessing all object's properties and methods. This is a common practice when programming scripts in Elipse Power, makes it easy to handle objects, and makes code more intelligible. Example:
Sub CommandButton1_Click()
  ' Assign the value 20 to InternalTag1's Value property
  ' which is inside Data.
  Set tag = Application.GetObject("Data.InternalTag1")
  tag.Value = 20
