Displays Tab |
This tab displays Pens corresponding to data available on the Connections tab. The available options when right-clicking a Display are described on the next table.
Available options on the contextual menu of a Display
Option |
Description |
Select Columns |
Allows selecting which columns are displayed for Pens |
Auto Update |
Enables or disables the auto-update mode |
Show Gridlines |
Shows or hides grid lines on Pens area |
Show Min/Max Points |
Shows or hides minimum and maximum points of Pens |
Show Local Legend |
Mostra uma legenda com o nome da Pena e a respectiva cor |
Interpolate |
Uses interpolation to draw a Display |
When selecting the Select Columns option, the window on the next figure is displayed.
Legend window
Available options on the Legend window
Option |
Description |
Available |
Available columns for viewing |
Add |
Moves the selected column to the Selected list |
Remove |
Removes the selected column from the Selected list |
Up |
Moves the selected column one position up on the Selected list |
Down |
Moves the selected column one position down on the Selected list |
Selected |
Columns selected for viewing |
NOTES |
•To reorder the columns of a Legend, use the Up or Down options. •The available options for columns of a Legend, including their width, only apply to the selected Display. |
Each Pen has a check box, which indicates whether they are visible on a Display, an icon with a color, and a name. When right-clicking a Pen, users can select the options described on the next table.
Available options on the contextual menu of a Pen
Option |
Description |
Bring to Front |
Moves the selected Pen one position up in the overlay order of Pens. The available options are Bring to Front: Moves the selected Pen to the first position or Bring Forward: Moves the selected Pen one position up |
Send to Back |
Moves the selected Pen one position down in the overlay order of Pens. The available options are Send to Back: Moves the selected Pen to the last position or Send Backward: Moves the selected Pen one position down |
Fit |
Fits the Pen from the selected Display on both vertical and horizontal axes |
Edit |
Allows editing information about the selected Pen |
Show Details |
Shows a window with detailed information about a Pen |
Delete Pen |
Removes the selected Pen from the Display |
NOTES |
•When deselecting the check box near a Pen, that Pen stops receiving real-time data. •Clicking the color icon of a Pen opens the Windows standard dialog box for selecting colors. |
When selecting the Edit option on the contextual menu of a Pen, the window on the next figure is displayed.
Edit window
Available options on the Edit window
Option |
Description |
Title |
Allows changing the title of a Pen |
Connection |
Allows selecting the type of connection of a Pen. Possible values are Discrete or Continuous |
Line type |
Allows selecting the type of line of a Pen. Possible values are None: No line, only dots, Solid: Solid line, Area: Draws the Pen's area, Dash: Dashed line, Dash Dot: Line with dash-dot, or Dash Dot Dot: Line with dash-dot-dot |
Point type |
Allows selecting the type of points of a Pen. Possible values are None: No indication of points, Circle, Square, Triangle, or Diamond |
Line width |
Allows configuring the width of the drawing line of a Pen |
Type |
Allows configuring the type of connection. Possible values are Don't connect bad points: Does not connect points with bad quality, Connect until bad: Connects points until quality turns bad, or Ignore bad: Ignores points with bad quality |
Scan (ms) |
Allows configuring the scan time of a Pen |
NOTE |
The Line type and Point type options cannot be configured simultaneously with the value None. |
When clicking the Show Details option on the contextual menu of a Pen, the window on the next figure is displayed.
Details window
Available options on the Details window
Option |
Description |
Connection |
Shows the name of a Pen's connection |
Source |
Shows a Pen's data source |
Status |
Shows the status of the last query of a Pen |
Duration |
Shows the duration time of the last query of a Pen |
Points received |
Shows the number of points received during the last query of a Pen |
Users can also edit vertical, Numeric, and horizontal, Time, Scales of a Display. To do so, right-click a Scale and select the Edit option. The next figures show the available options for each Scale.
Numeric Scale window
Available options on the Numeric Scale window
Option |
Description |
Title |
Title of the Vertical Scale |
Show Title |
Enables or disables viewing the Vertical Scale |
Top |
Maximum value of the Vertical Scale |
Bottom |
Minimum value of the Vertical Scale |
Show gridlines |
Enables or disables viewing Vertical Scale grid lines relative to Time Scale |
Digital axis scale |
Adjusts the Vertical Scale for viewing digital or discrete variables |
Auto fit |
When selecting this option, Pens using this Vertical Scale are permanently adjusted to the visible period. In this mode, users cannot drag the Vertical Scale |
Time Scale window
Available options on the Time Scale window
Option |
Description |
Begin |
Initial date and time displayed on the Time Scale |
End |
Final date and time displayed on the Time Scale |
Show gridlines |
Shows or hides grid lines relative to the Time Scale |
NOTE |
To add or remove Numeric Scales, use the |
