Screen Structure
Screen Structure
A Frame is an object that organizes and structures an interface, creating composed views for users inside Elipse Power Viewer's main window or inside a browser.
On a Frame, users can create Splitters to view different Screens at the same time. Each Splitter can also display a URL, an Excel spreadsheet, a Word document, or a PDF document.
Positioning of Splitters inside a Frame can be horizontal or vertical. A Splitter allows inserting inside it other Splitters. At each pair of new Splitters created by the Split Horizontal and Split Vertical options, there is always a Main Splitter and a Secondary Splitter. Only a Main Splitter contains a value that explicitly define its position, and a Secondary Splitter gets the remaining value.
Screen Objects are graphical elements that can be inserted on Screens to create a visual interface for a process. They can be created using the toolbar of a Screen or using the Objects menu.
Once selected an object to create, keep the left mouse button pressed on a Screen area while moving the mouse pointer (a dotted rectangle shows this object's size and shape). When releasing the left mouse button, this object is placed inside that specific area.
