Elipse Gateway |
Elipse Power allows implementing a gateway of protocols. Elipse Gateway provides a gateway via software that do not need additional hardware and ensures efficiency on data transmission. This solution can be used by substations or by generation units to report data to control centers and power regulation agencies, or simply to exchange data between two systems. The structure of Elipse Gateway is the following.
Elipse Gateway's structure
To create a communication gateway between two Drivers, master and slave, on the same application, follow the procedures on the next exercises.
