Ratio
Ratio
Elipse Power's Screen Importer creates Screen objects proportionally, by considering the size of an object in an electrical modeler, the drawing area of a model, and the size of a Screen. After performing an import operation, if needed, delete all objects created on that Screen, perform the necessary adjustments, and then repeat this import process, until the resulting Screen is considered satisfactory.
For Screen objects with the best possible appearance, that is, Screen objects created with their original sizes, users can rely on the following formulas:
CanvasTop = (Width / 2000) * Size
CanvasBottom = (Height / 2000) * Size
Where:
CanvasTop: Width of electrical modeler's drawing area
CanvasBottom: Height of electrical modeler's drawing area
Width: Width of operation Screen
Height: Height of operation Screen
Size: Object size in electrical modeler
