Configuration
Configuration
When a Storage is created on an application, a list of definitions for its recording fields is then displayed.
Storage fields
Storage fields
For further queries on data, all searches are performed via Tag path or property being stored (the Source field). The Name property is only used in case the Source field contains an expression. Therefore, if expressions are not used in the Source field, there is no need to consider the Name property.
