Alarm Summary
Alarm Summary
1.Add an E3Alarm object that fills the whole area of a Screen. Right-click a Screen and select the Insert - E3Alarm option.
Inserting an E3Alarm
2.Open the Properties Window of this object and, on Connections tab, configure the name of an Alarm Server on Alarm Server column of the default Connection with the Server added to the application, by using AppBrowser. On Filters tab, select the Alarms and Events item on the Filter by type option of the default Filter (by clicking Configure).
Filter properties
Filter properties
3.On the Columns tab, select the following fields:
Acked
Operator
Area
Message
Severity
DateTime (in)
DateTime (out)
DateTime (ack)
Formatted value
Columns tab
Columns tab
