Elipse Power
Elipse Power
Fixed a behavior in Load Shedding, which could shed a load with active power greater than needed if several loads had the same priority. This bug occurred since v3.5.226.
Implemented license lending in Elipse Power Studio.
The Commands and Protections tabs in PowerExplorer now display a description of the electrical phase near the Protection Acronym. This bug occurred since v4.0.60.
Fixed a problem of not showing the legend of Measurements when the PowerExplorer was opened from a Protection. This bug occurred since v4.0.77.
Fixed a problem in PowerExplorer that did not show units of Analog Measurements the first time the window was opened for Distribution Load-type objects.This bug occurred since v4.0.105.
Fixed a problem of not showing the TimeStamp column after closing and opening a PowerExplorer object which was kept with a reference by the user. This bug occurred since v4.0.122.
Added warning messages when some Screen object classes are not found during the import of Screen objects. This bug occurred since v3.5.123.
Fixed the alignment of objects in PowerControls library, and now terminals are always centered. This bug occurred since v3.5.236.
It is not allowed to import a Substation of Feeder to a Screen with the same name anymore. This bug occurred since v3.5.81.
Fixed positions of terminals 2 and 3 of the Three-Winding Transformer (they were inverted). This bug occurred since v4.0.216.
Fixed the update in Studio's Property List when a change in the model file fails (the ModelFile property) in PowerConfig. This bug occurred since v3.5.81.
Fixed a typing error when selecting the electrical model file in PowerConfig. This bug occurred since v3.5.81.
Fixed a focus problem when editing the Value column of a Measurement Source of type Operator. This bug occurred since v3.5.81.
Fixed a problem when clicking the Measurement column in PowerExplorer, which selected the equivalent field on Value column. This bug occurred since v3.5.81.
Change the point of generation of OnCommand and OnCommandEx events, so that the order of OnSelect and OnOperate does not invert when using the Select Before Operate option in the Command. This bug occurred since v3.5.81.
The PositiveFlowIn internal measurements of Terminals are not sent to PowerEngine anymore if the device has a null (zero) ID. This bug occurred since v4.0.122.
Removed the object SE1.Capacitor1 from the demonstration application, as it was not part of the electrical model and was not used anywhere. This bug occurred since v3.5.141.
Fixed the symbol of "kilo" prefix in Analog Measurements in PowerExplorer. This bug occurred since v3.5.81.
Fixed the String that identifies the metrical prefix 'kilo' in PowerDisplay library. Now the String is identified by 'k' (lowercase). This bug occurred since v3.5.142.
Fixed a problem in PowerExplorer that always used a dot to format measurements with decimal places. It must use the same separator configured by the user in Windows regional configurations. This bug occurred since v3.5.81.
In the electrical model of the demonstration application of Elipse Power, the Branch1 connection was replaced by a Jumper to avoid exceeding the limit of 100 measurements of Demo mode, if users perform a data syncing. Fixed the Feeder's short names. This bug occurred since v3.5.141.
