Documentation
Documentation
Fixed the usage example of the InsertColumn method of a Pen's Legend in Elipse Power Reference and Scripts Manual. This bug occurred since v3.2.140.
Added the description of Source property of a Multisource Link Row in Elipse Power Reference and Scripts Manual. This bug occurred since v3.2.175.
Added descriptions for OnRead events of OPC Block, OPC Block Element, and OPC Tag objects in Elipse Power Reference and Scripts Manual. This bug occurred since v1.18.147.
Added information about the Storage Session object in Elipse Power Reference and Scripts Manual, related to the AddField, AddValue, and Commit methods. This bug occurred since v2.5.128.
Created separated topics to enlist events, methods, and properties of Link collections (the Links property) and Discrete Alarm Source Subconditions (the Subconditions property) in Elipse Power Reference and Scripts Manual. This bug occurred since v4.0.155.
Added a usage example for the ShowPowerExplorer method of Viewer in Elipse Power Reference and Scripts Manual. This bug occurred since v3.5.258.
Created in Elipse Power Reference and Scripts Manual a new topic in common properties of Server Objects, which contains common properties of Server Objects behaving as Alarm Areas. This bug occurred since v4.0.169.
Fixed the description of the CommandUnit parameter on Power Configuration object's OnCommand event on chapter Server Objects - Elipse Power - Configuration - Power Configuration - Events in <DOC_POWER_SCRIPT%> to state that this parameter is the Command Unit object itself. This bug occurred since v3.5.245.
Updated the description of the Write method of the I/O Driver object in Elipse Power Reference and Scripts Manual to remove a mention to an ever-synchronous data writing.This bug occurred since v3.0.57.
Performed corrections in several texts and exercises of Elipse Power Tutorial. This bug occurred since v3.5.310.
Added a new topic about Multiple Links in chapter Links of Elipse Power Tutorial. This bug occurred since v3.5.164.
Performed corrections in several texts and exercises of the Elipse Power Tutorial. This bug occurred since v3.5.164.
Added a note suggesting a change in the background color of Screens imported on topic Operation Diagram - Importing Screen Objects of Elipse Power Tutorial. Also fixed the name of the SetPoint object on topic Report - Alarm Report - Page Numbering, of this Tutorial. This bug occurred since v4.0.94.
Fixed the description of the Saves and Runs the Domain button of Elipse Power Studio in Elipse Power User's Guide and Elipse Power Tutorial. This bug occurred since v3.5.163.
Updated Elipse Power Tutorial on the chapters where there are images with the configuration window for Analog Alarms. This bug occurred since v4.0.187.
Removed references to specific versions of Elipse Power in documents where this information is not needed.
Fixed the screen resolution of CHM files to comply with project configuration. Now all files are opened with the resolution of 1024 by 768 pixels. This bug occurred since v3.5.183.
Fixed the example of the topic Reports - Usage Examples - Capturing a Screen and Generating a Print Preview, in Elipse Power User's Guide. This bug occurred since v1.19.87.
Fixed the item ActorID on topic Alarms - Alarm Server - Configurations for Alarm Table Generation in Elipse Power User's Guide. This bug occurred since v1.19.383.
