License Type Information
This section contains information about the properties of a License Type Information (LicenseCounterNode) object. This object does not contain events nor methods associated to it.
NOTE
Using brackets when referencing this object in scripts, such as "[?Server].License.IoDrivers", is mandatory.
The currently available License Type Information objects are the following:
ViewersControl: Elipse Power Viewer licenses
ViewersOnly: Elipse Power Viewer Only licenses
Studios: Elipse Power Studio licenses
IoPoints: I/O points licenses
StorageTags: Storage Tags licenses
RemoteServers: Remote Domain server licenses
RemoteClients: Remote Domain client licenses
OpcServer: OPC server licenses
IoDrivers: Driver licenses for any Driver, that is, unlimited Driver licenses
IoDriversId<nnn>: Driver licenses, where nnn is a number between 1 (one) and 65535, when there are licenses for a specific I/O Driver ID
PowerSubstations: Substation licenses
PowerFeeders: Feeder licenses
PowerMeasurements: Measurement licenses
WindTurbines: Wind Turbine licenses
PowerPvArrays: Photovoltaic Array licenses
PowerInverters: Inverter licenses
PowerFlowInputs: Power Flow Input licenses
LoadShedBrakers: Load Shedding Breaker licenses
PowerLoads: Load licenses
PwrViewGeneratorLoads: Schematic View Generation Load licenses
StateEstimatorLoads: State Estimator Load licenses
DistLoadModellingLoads: Distribution Load licenses
SelfHealingBreakers: Self-Healing Recloser and Breaker licenses
