Bay
Bay
A Bay (EDBBAY) object does not contain events, methods, or properties associated to it, only general ones. These ones can be viewed on section Common Properties.
NOTE
The class of a Bay object, regarding scripts, is different on the following objects:
On a Wind Power Plant object, the class of a Bay object is EDBWINDPOWERBAY.
On a Photovoltaic Power Plant object, the class of a Bay object is EDBPHOTOVOLTAICPOWERBAY.
