Connections
Connections
This section contains information about the Connection-type objects of the Electrical Model. The available connections on this section are the following:
Branch
Busbar Terminal
Direct Current Branch
Direct Current Jumper
Direct Current Node
External Node
Graphical Vertex
Jumper
Junction Box Terminal
Node
Terminal
Transmission Line Segment
