FollowEnergized
FollowEnergized
Boolean This property indicates whether a voltage color for de-energized devices must be automatic or not. If this property is configured as True, the voltage color for de-energized devices is automatically calculated as a darker version of the color indicated in the ColorEnergized property. Otherwise, the voltage color for de-energized devices is the color informed in the ColorDeEnergized property.
