ScreenAlignment |
Controls the alignment, given by Elipse Power Viewer, of all Screens that do not specify a value different from default. Possible values for this property are the following:
The next figure shows an Elipse Power Viewer's contextual menu at run time, with the respective configuration options of this property.
Options for Elipse Power Viewer's ScreenAlignment property at run time
