DataType |
Property filled when Elipse Power connects to an OPC UA server, which indicates the data type on the OPC UA server. This property is initially filled during the browsing process, if performed, and in any communication or connection to the OPC UA server. Values below 1,000 are scalar and values above 1,000 are arrays. This is a read-only property. Possible values for this property are the following:
•17: udtNodeId (OPC UA Node Identifier, formatted as a three-element array in Elipse Power)
•18: udtExpandedNodeId (Expanded OPC UA Node Identifier, formatted as a three-element array in Elipse Power)
•22: udtStructure (Indicates this is an OPC UA complex data type, but not specific, formatted as an array where each element is a member of the structure)
•25: udtDiagnosticInfo
•1000: udtArrayUnknown (Generic array, with unknown data types)
•1001: udtArrayBoolean
•1002: udtArraySByte
•1003: udtArrayByte
•1004: udtArrayInt16
•1005: udtArrayUInt16
•1006: udtArrayInt32
•1007: udtArrayUInt32
•1008: udtArrayInt64
•1009: udtArrayUInt64
•1010: udtArrayFloat
•1011: udtArrayDouble
•1012: udtArrayString
•1013: udtArrayDateTime
•1014: udtArrayGuid
•1015: udtArrayByteString
•1016: udtArrayXmlElement
•1017: udtArrayNodeId
•1018: udtArrayExpandedNodeId
•1019: udtArrayStatusCode
•1020: udtArrayQualifiedName
•1021: udtArrayLocalizedText
•1022: udtArrayStructure
•1023: udtArrayDataValue
•1024: udtArrayVariant
•Structures defined by specific servers, not compatible with the OPC UA standard, are not read by Elipse Power. •Data types udtArrayQualifiedName, udtArrayLocalizedText, udtStructure, udtArrayStructure, udtArrayDataValue, and udtArrayUnknown do not allow writing in the current version of Elipse Power, because Elipse Power uses a simplified formatting of these data types. •Data types ServiceCounterDataType (array with two positions), BuildIndfo (array with six positions), Argument (array with six positions), ApplicationDescription (array with eight positions), SessionDiagnosticsDataType (array with 44 positions), SessionSecurityDiagnosticsDataType (array with 10 positions), SubscriptionsDiagnosticsDataType (array with 31 positions), ServerDiagnosticsSummaryDataType (array with 12 positions), ServerStatusDataType (array with six positions), EuInformation (array with four positions), Range (array with two positions), TimeZoneDataType (array with two positions), DiagnosticInfo (array with seven positions), StatusResult (array with two positions), ComplexNumberType (array with two positions), DoubleComplexNumberType (array with two positions), XVType (array with two positions), RedundanteServerSataType (array with three positions), SamplingIntervalDiagnosticsDataType (array with four positions), EnumValueType (array with three positions), EndpointUrlListDataType (array with two positions), and NetworkGroupDataType (array with three positions) are displayed as udtStructure, but Elipse Power handles the specific data type. •In the current version, Elipse Power only allows single-dimension arrays, that is, it does not allow matrices as data types. |
