EnableScaling |
This property enables or disables a scale of values for the value sent to or received from a device. If this property is set to True, any value coming from a device suffers a scale adjustment according to DeviceHigh, DeviceLow, EUHigh, and EULow properties before setting it to the Value property. The same behavior occurs when a writing is needed, when the value available in Value suffers a scale adjustment (without changing the Value property) and then sent to a device. If the EnableScaling property is set to False, no scale adjustment is performed in both directions (reading and writing). Default value of this property is False.
