DiscardInterval |
This property works with the DiscardTimeUnit property. The DiscardInterval property indicates a time interval in which data from a Self-Healing-type Electrical Study is stored on a database table, until it is discarded. Default value of this property is 1 (one time unit indicated by the DiscardTimeUnit property). If this property is set to a value less than the value of the BackupDiscardInterval property, Elipse Power automatically sets the value of the BackupDiscardInterval property as double the value of this property.
