TransferenceStatus |
Indicates the status of the Feeder that is energizing this Terminal. This is a read-only property. Possible values for this property are the following:
•0 - tsNotTransferred: Terminal is energized by the Feeder that contains it
•1 - tsTransferredToSingle: Terminal is energized by another Feeder, whose color is indicated in the TransferenceColor property
•2 - tsTransferredToMultiple: Terminal is energized by several Feeders, therefore the color indicated in the TranferenceColor property is white (RGB(255, 255, 255))
