ProtectionType |
Type of Protection used in the Protection object. This property configures the Protection standard created in the Power Configuration object. This property's value can be configured in the Property List, as well as in the Type column of the Design tab of Feeder, Photovoltaic Power Plant, Substation, Transmission Line, and Wind Power Plant objects. This property cannot be changed while this object is active and cannot be an empty String.
